Run Time: 0.001178
Run Time: 0.000690
Run Time: 0.000322
Run Time: 0.002482
Run Time: 0.000526
Params: 0, O<, O<, XF\Pub\Controller\Forum, List, valid, , 1714947979,
Run Time: 0.000120
Run Time: 0.000672
Params: 1714947079
Run Time: 0.000476
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 154 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714947079)
Run Time: 0.000596
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 154 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712355979)
Run Time: 0.001386
Run Time: 0.000984
Run Time: 0.000734
Run Time: 0.000153
Run Time: 0.000284
Run Time: 0.001286
Run Time: 0.001933
