Run Time: 0.001457
Run Time: 0.001137
Run Time: 0.000321
Run Time: 0.002603
Run Time: 0.000593
Params: 0, ti, ti, XF\Pub\Controller\Forum, List, valid, , 1714768179,
Run Time: 0.000795
Params: 1714767279
Run Time: 0.000500
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 63 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714767279)
Run Time: 0.000584
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 63 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712176179)
Run Time: 0.001509
Run Time: 0.001238
Run Time: 0.000880
Run Time: 0.000242
Run Time: 0.000210
Run Time: 0.000280
Run Time: 0.000387
Run Time: 0.001442
Run Time: 0.002299
