Run Time: 0.001386
Run Time: 0.000310
Run Time: 0.001431
Run Time: 0.000312
Run Time: 0.004736
Run Time: 0.001025
Params: 0, Q^, Q^, XF\Pub\Controller\Forum, List, valid, , 1715109571,
Run Time: 0.000151
Run Time: 0.000863
Params: 1715108671
Run Time: 0.000443
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715108671)
Run Time: 0.000590
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712517571)
Run Time: 0.001443
Run Time: 0.001251
Run Time: 0.000998
Run Time: 0.000312
Run Time: 0.000248
Run Time: 0.000378
Run Time: 0.000356
Run Time: 0.002031
Run Time: 0.002144
