Run Time: 0.001350
Run Time: 0.000230
Run Time: 0.000297
Run Time: 0.000830
Run Time: 0.000322
Run Time: 0.005021
Run Time: 0.000620
Params: 0, ݁, ݁, XF\Pub\Controller\Forum, List, valid, , 1714849771,
Run Time: 0.000890
Params: 1714848871
Run Time: 0.000487
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 56 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714848871)
Run Time: 0.000861
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 56 | Using where |
Run Time: 0.000256
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712257771)
Run Time: 0.001468
Run Time: 0.000962
Run Time: 0.001213
Run Time: 0.000280
Run Time: 0.000247
Run Time: 0.000247
Run Time: 0.000314
Run Time: 0.000374
Run Time: 0.001454
Run Time: 0.002236
bytes_received | 941939 |
bytes_received_change_user_packet | 714822 |
bytes_received_real_data_ps | 702787 |
