Run Time: 0.001283
Run Time: 0.000336
Run Time: 0.000329
Run Time: 0.001394
Run Time: 0.000410
Run Time: 0.002885
Run Time: 0.000687
Params: 0, t(5, t(5, XF\Pub\Controller\Forum, List, valid, , 1714841251,
Run Time: 0.001097
Params: 1714840351
Run Time: 0.000607
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714840351)
Run Time: 0.000856
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 118 | Using where |
Run Time: 0.000305
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712249251)
Run Time: 0.001700
Run Time: 0.001384
Run Time: 0.001568
Run Time: 0.000473
Run Time: 0.000382
Run Time: 0.000360
Run Time: 0.000242
Run Time: 0.000365
Run Time: 0.000414
Run Time: 0.001920
Run Time: 0.000285
Run Time: 0.002121
bytes_received | 941981 |
bytes_received_change_user_packet | 714864 |
bytes_received_real_data_ps | 702829 |
