Run Time: 0.001089
Run Time: 0.000802
Run Time: 0.000309
Run Time: 0.002966
Run Time: 0.000623
Params: 0, ݈, ݈, XF\Pub\Controller\Forum, List, valid, , 1714294806,
Run Time: 0.000918
Params: 1714293906
Run Time: 0.000458
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 42 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714293906)
Run Time: 0.000706
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 42 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711702806)
Run Time: 0.001862
Run Time: 0.002073
Run Time: 0.001316
Run Time: 0.000301
Run Time: 0.000299
Run Time: 0.000286
Run Time: 0.000255
Run Time: 0.000291
Run Time: 0.000373
Run Time: 0.001722
Run Time: 0.000319
Run Time: 0.002283
bytes_received | 941545 |
bytes_received_change_user_packet | 714428 |
bytes_received_real_data_ps | 702411 |
