Run Time: 0.001155
Run Time: 0.000304
Run Time: 0.000230
Run Time: 0.000865
Run Time: 0.000320
Run Time: 0.003099
Run Time: 0.000951
:Mb,
:Mb, XF\Pub\Controller\Forum, List, valid, , 1714591978,
Run Time: 0.000133
Run Time: 0.000805
Params: 1714591078
Run Time: 0.000315
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 16 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714591078)
Run Time: 0.000609
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 16 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711999978)
Run Time: 0.001417
Run Time: 0.001038
Run Time: 0.000881
Run Time: 0.000229
Run Time: 0.000261
Run Time: 0.000375
Run Time: 0.001563
Run Time: 0.002179
bytes_received | 941807 |
bytes_received_change_user_packet | 714690 |
bytes_received_real_data_ps | 702683 |
