Run Time: 0.001251
Run Time: 0.000765
Run Time: 0.000311
Run Time: 0.002356
Run Time: 0.000526
Params: 0, tM, tM, XF\Pub\Controller\Forum, List, valid, , 1714802145,
Run Time: 0.000137
Run Time: 0.000612
Params: 1714801245
Run Time: 0.000455
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 83 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714801245)
Run Time: 0.000596
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 83 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712210145)
Run Time: 0.001313
Run Time: 0.000987
Run Time: 0.000883
Run Time: 0.000284
Run Time: 0.001520
Run Time: 0.001847
