Run Time: 0.001303
Run Time: 0.000765
Run Time: 0.000308
Run Time: 0.002778
Run Time: 0.000543
Params: 0, d", d", XF\Pub\Controller\Forum, List, valid, , 1714617177,
Run Time: 0.000185
Run Time: 0.000841
Params: 1714616277
Run Time: 0.000534
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714616277)
Run Time: 0.000621
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712025177)
Run Time: 0.001771
Run Time: 0.001055
Run Time: 0.000895
Run Time: 0.000227
Run Time: 0.000287
Run Time: 0.001601
Run Time: 0.001851
bytes_received | 941809 |
bytes_received_change_user_packet | 714692 |
bytes_received_real_data_ps | 702685 |
