Run Time: 0.001419
Run Time: 0.000236
Run Time: 0.000772
Run Time: 0.000610
Run Time: 0.002782
Run Time: 0.000552
Params: 0, t3u, t3u, XF\Pub\Controller\Forum, List, valid, , 1714885052,
Run Time: 0.000149
Run Time: 0.001269
Params: 1714884152
Run Time: 0.000533
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 116 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714884152)
Run Time: 0.000645
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 116 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712293052)
Run Time: 0.001669
Run Time: 0.001261
Run Time: 0.001686
Run Time: 0.000285
Run Time: 0.000302
Run Time: 0.000239
Run Time: 0.000280
Run Time: 0.000390
Run Time: 0.001605
Run Time: 0.003581
