Run Time: 0.001214
Run Time: 0.000240
Run Time: 0.000737
Run Time: 0.000315
Run Time: 0.002556
Run Time: 0.000588
Params: 0, Fe, Fe, XF\Pub\Controller\Forum, List, valid, , 1714763565,
Run Time: 0.000145
Run Time: 0.001105
Params: 1714762665
Run Time: 0.000510
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 102 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714762665)
Run Time: 0.000638
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 102 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712171565)
Run Time: 0.001337
Run Time: 0.001031
Run Time: 0.000922
Run Time: 0.000227
Run Time: 0.000189
Run Time: 0.000242
Run Time: 0.000339
Run Time: 0.001785
Run Time: 0.001995
