Run Time: 0.001363
Run Time: 0.001041
Run Time: 0.000644
Run Time: 0.004396
Run Time: 0.000806
Params: 0, ڨ, ڨ, XF\Pub\Controller\Forum, List, valid, , 1714975110,
Run Time: 0.000205
Run Time: 0.001265
Params: 1714974210
Run Time: 0.000702
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714974210)
Run Time: 0.000776
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712383110)
Run Time: 0.002124
Run Time: 0.001180
Run Time: 0.001020
Run Time: 0.000258
Run Time: 0.000241
Run Time: 0.001682
Run Time: 0.002210
