Run Time: 0.001202
Run Time: 0.000684
Run Time: 0.000297
Run Time: 0.002436
Run Time: 0.000517
Params: 0, ٶ-, ٶ-, XF\Pub\Controller\Forum, List, valid, , 1714872444,
Run Time: 0.000862
Params: 1714871544
Run Time: 0.000557
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 150 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714871544)
Run Time: 0.000617
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 150 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712280444)
Run Time: 0.001233
Run Time: 0.000963
Run Time: 0.000884
Run Time: 0.000204
Run Time: 0.000250
Run Time: 0.001265
Run Time: 0.001776
