Run Time: 0.001148
Run Time: 0.000259
Run Time: 0.000839
Run Time: 0.000300
Run Time: 0.002303
Run Time: 0.000467
Params: 0, uĸ, uĸ, XF\Pub\Controller\Forum, List, valid, , 1714827678,
Run Time: 0.000142
Run Time: 0.000601
Params: 1714826778
Run Time: 0.000462
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714826778)
Run Time: 0.000556
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712235678)
Run Time: 0.001174
Run Time: 0.000840
Run Time: 0.000839
Run Time: 0.000251
Run Time: 0.000301
Run Time: 0.001283
Run Time: 0.000157
Run Time: 0.001888
bytes_received | 941792 |
bytes_received_change_user_packet | 714675 |
bytes_received_real_data_ps | 702668 |
