Run Time: 0.001256
Run Time: 0.000208
Run Time: 0.001173
Run Time: 0.000449
Run Time: 0.002635
Run Time: 0.000550
Params: 0, O;, O;, XF\Pub\Controller\Forum, List, valid, , 1715130146,
Run Time: 0.000143
Run Time: 0.000797
Params: 1715129246
Run Time: 0.000458
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 173 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715129246)
Run Time: 0.000599
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 173 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712538146)
Run Time: 0.001198
Run Time: 0.000997
Run Time: 0.000750
Run Time: 0.000225
Run Time: 0.001962
Run Time: 0.002030
