Run Time: 0.000934
Run Time: 0.000679
Run Time: 0.000312
Run Time: 0.002415
Run Time: 0.000589
Params: 0, D, D, XF\Pub\Controller\Forum, List, valid, , 1715032317,
Run Time: 0.000787
Params: 1715031417
Run Time: 0.000452
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 143 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715031417)
Run Time: 0.000605
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 143 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712440317)
Run Time: 0.001301
Run Time: 0.001000
Run Time: 0.000918
Run Time: 0.000252
Run Time: 0.000253
Run Time: 0.000384
Run Time: 0.001321
Run Time: 0.000250
Run Time: 0.001945
