Run Time: 0.001306
Run Time: 0.000301
Run Time: 0.000238
Run Time: 0.000806
Run Time: 0.000359
Run Time: 0.002565
Run Time: 0.000467
Params: 0, ukZ, ukZ, XF\Pub\Controller\Forum, List, valid, , 1715100770,
Run Time: 0.000140
Run Time: 0.000646
Params: 1715099870
Run Time: 0.000419
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 106 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715099870)
Run Time: 0.000564
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 106 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712508770)
Run Time: 0.001382
Run Time: 0.001194
Run Time: 0.000873
Run Time: 0.000229
Run Time: 0.000301
Run Time: 0.000358
Run Time: 0.001356
Run Time: 0.001961
