Run Time: 0.001407
Run Time: 0.000290
Run Time: 0.000863
Run Time: 0.000308
Run Time: 0.002360
Run Time: 0.000647
Params: 0, L , L , XF\Pub\Controller\Forum, List, valid, , 1715196469,
Run Time: 0.000832
Params: 1715195569
Run Time: 0.000475
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715195569)
Run Time: 0.000710
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 136 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712604469)
Run Time: 0.001442
Run Time: 0.001113
Run Time: 0.000859
Run Time: 0.000239
Run Time: 0.000348
Run Time: 0.000405
Run Time: 0.001542
Run Time: 0.002224
