Run Time: 0.001172
Run Time: 0.001071
Run Time: 0.000334
Run Time: 0.002821
Run Time: 0.000635
:', XF\Pub\Controller\Forum, List, valid, , 1714985000,
Run Time: 0.000763
Params: 1714984100
Run Time: 0.000435
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714984100)
Run Time: 0.000579
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712393000)
Run Time: 0.001399
Run Time: 0.000990
Run Time: 0.000813
Run Time: 0.000204
Run Time: 0.000250
Run Time: 0.000362
Run Time: 0.001679
Run Time: 0.000287
Run Time: 0.002416
