Run Time: 0.001127
Run Time: 0.000697
Run Time: 0.000290
Run Time: 0.002753
Run Time: 0.000535
Params: 0, ^, ^, XF\Pub\Controller\Forum, List, valid, , 1714869040,
Run Time: 0.000132
Run Time: 0.000627
Params: 1714868140
Run Time: 0.000420
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714868140)
Run Time: 0.000520
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712277040)
Run Time: 0.001347
Run Time: 0.001079
Run Time: 0.000809
Run Time: 0.000211
Run Time: 0.000274
Run Time: 0.001638
Run Time: 0.002041
