Run Time: 0.001719
Run Time: 0.000268
Run Time: 0.001103
Run Time: 0.002550
Run Time: 0.001015
Params: 0, ӆ, ӆ, XF\Pub\Controller\Forum, List, valid, , 1714990314,
Run Time: 0.000804
Params: 1714989414
Run Time: 0.000484
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 132 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714989414)
Run Time: 0.000627
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 132 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712398314)
Run Time: 0.001396
Run Time: 0.001141
Run Time: 0.000923
Run Time: 0.000253
Run Time: 0.000317
Run Time: 0.000357
Run Time: 0.001680
Run Time: 0.000244
Run Time: 0.001907
