Run Time: 0.001416
Run Time: 0.000305
Run Time: 0.000851
Run Time: 0.000320
Run Time: 0.002564
Run Time: 0.001096
Params: 0, ܌, ܌, XF\Pub\Controller\Forum, List, valid, , 1714968198,
Run Time: 0.000277
Run Time: 0.001489
Params: 1714967298
Run Time: 0.000618
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714967298)
Run Time: 0.000737
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712376198)
Run Time: 0.001640
Run Time: 0.001477
Run Time: 0.001382
Run Time: 0.000414
Run Time: 0.000266
Run Time: 0.000271
Run Time: 0.000279
Run Time: 0.000271
Run Time: 0.000367
Run Time: 0.000462
Run Time: 0.001768
Run Time: 0.000223
Run Time: 0.002442
