Run Time: 0.001684
Run Time: 0.000334
Run Time: 0.001206
Run Time: 0.000312
Run Time: 0.002542
Run Time: 0.000697
Params: 0, ڜ#, ڜ#, XF\Pub\Controller\Forum, List, valid, , 1715001113,
Run Time: 0.001112
Params: 1715000213
Run Time: 0.000525
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715000213)
Run Time: 0.000712
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712409113)
Run Time: 0.001712
Run Time: 0.001210
Run Time: 0.000991
Run Time: 0.000211
Run Time: 0.000225
Run Time: 0.000225
Run Time: 0.000372
Run Time: 0.001628
Run Time: 0.002367
