Run Time: 0.001397
Run Time: 0.000665
Run Time: 0.002452
Run Time: 0.000482
Params: 0, 4UL, 4UL, XF\Pub\Controller\Forum, List, valid, , 1715107159,
Run Time: 0.000148
Run Time: 0.000688
Params: 1715106259
Run Time: 0.000405
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 133 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715106259)
Run Time: 0.000583
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 133 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712515159)
Run Time: 0.001414
Run Time: 0.000887
Run Time: 0.000854
Run Time: 0.000459
Run Time: 0.000230
Run Time: 0.001565
Run Time: 0.001742
