Run Time: 0.001093
Run Time: 0.000650
Run Time: 0.000360
Run Time: 0.002535
Run Time: 0.000526
Params: 0, I, I, XF\Pub\Controller\Forum, List, valid, , 1714764558,
Run Time: 0.000147
Run Time: 0.000621
Params: 1714763658
Run Time: 0.000506
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 135 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714763658)
Run Time: 0.000617
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 135 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712172558)
Run Time: 0.001248
Run Time: 0.000863
Run Time: 0.000723
Run Time: 0.000240
Run Time: 0.000159
Run Time: 0.000328
Run Time: 0.001304
Run Time: 0.001823
