Run Time: 0.001239
Run Time: 0.000257
Run Time: 0.000226
Run Time: 0.000820
Run Time: 0.000312
Run Time: 0.002524
Run Time: 0.000649
Params: 0, 㡄, 㡄, XF\Pub\Controller\Forum, List, valid, , 1715156770,
Run Time: 0.000150
Run Time: 0.000859
Params: 1715155870
Run Time: 0.000571
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715155870)
Run Time: 0.000620
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712564770)
Run Time: 0.001940
Run Time: 0.002098
Run Time: 0.001099
Run Time: 0.000268
Run Time: 0.000314
Run Time: 0.000227
Run Time: 0.000320
Run Time: 0.000403
Run Time: 0.001923
Run Time: 0.000185
Run Time: 0.002046
bytes_received | 946578 |
bytes_received_change_user_packet | 719461 |
bytes_received_real_data_ps | 707288 |
