Run Time: 0.001267
Run Time: 0.000743
Run Time: 0.000288
Run Time: 0.002438
Run Time: 0.000536
;ړ,
;ړ, XF\Pub\Controller\Forum, List, valid, , 1714250728,
Run Time: 0.000144
Run Time: 0.000913
Params: 1714249828
Run Time: 0.000384
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 75 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714249828)
Run Time: 0.000696
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 75 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711658728)
Run Time: 0.001515
Run Time: 0.001102
Run Time: 0.000934
Run Time: 0.000246
Run Time: 0.000185
Run Time: 0.000225
Run Time: 0.000209
Run Time: 0.001507
Run Time: 0.001788
bytes_received | 941547 |
bytes_received_change_user_packet | 714430 |
bytes_received_real_data_ps | 702413 |
