Run Time: 0.001145
Run Time: 0.000293
Run Time: 0.001196
Run Time: 0.000376
Run Time: 0.002864
Run Time: 0.000541
Params: 0, vxm, vxm, XF\Pub\Controller\Forum, List, valid, , 1714882437,
Run Time: 0.000303
Run Time: 0.000917
Params: 1714881537
Run Time: 0.000477
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714881537)
Run Time: 0.000585
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712290437)
Run Time: 0.001399
Run Time: 0.001229
Run Time: 0.001144
Run Time: 0.000248
Run Time: 0.000261
Run Time: 0.000375
Run Time: 0.001968
Run Time: 0.002825
