Run Time: 0.001129
Run Time: 0.000677
Run Time: 0.000315
Run Time: 0.002387
Run Time: 0.000566
Params: 0, 8-, 8-, XF\Pub\Controller\Forum, List, valid, , 1714937763,
Run Time: 0.000628
Params: 1714936863
Run Time: 0.000476
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714936863)
Run Time: 0.000596
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712345763)
Run Time: 0.001433
Run Time: 0.000998
Run Time: 0.000798
Run Time: 0.000243
Run Time: 0.000260
Run Time: 0.001212
Run Time: 0.001905
