Run Time: 0.001210
Run Time: 0.000717
Run Time: 0.000388
Run Time: 0.002578
Run Time: 0.000493
Params: 0, Y, Y, XF\Pub\Controller\Forum, List, valid, , 1715041433,
Run Time: 0.000819
Params: 1715040533
Run Time: 0.000482
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 117 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715040533)
Run Time: 0.000726
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 117 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712449433)
Run Time: 0.001672
Run Time: 0.001159
Run Time: 0.001125
Run Time: 0.000456
Run Time: 0.000249
Run Time: 0.000238
Run Time: 0.000337
Run Time: 0.000345
Run Time: 0.002044
Run Time: 0.000240
Run Time: 0.002188
