Run Time: 0.001240
Run Time: 0.000245
Run Time: 0.000744
Run Time: 0.002434
Run Time: 0.000624
Params: 0, wmw, wmw, XF\Pub\Controller\Forum, List, valid, , 1715748849,
Run Time: 0.000143
Run Time: 0.000774
Params: 1715747949
Run Time: 0.000371
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 16 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715747949)
Run Time: 0.000579
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 16 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713156849)
Run Time: 0.001311
SIMPLE | xf_thread | range | last_post_date | last_post_date | 4 | | 36 | Using where |
Run Time: 0.001173
Run Time: 0.000981
Run Time: 0.000298
Run Time: 0.000209
Run Time: 0.000250
Run Time: 0.000369
Run Time: 0.000398
Run Time: 0.001655
Run Time: 0.000358
Run Time: 0.000324
Run Time: 0.003711
bytes_received | 1005722 |
packets_received | 3503 |
protocol_overhead_in | 14012 |
bytes_received_change_user_packet | 778605 |
packets_received_change_user | 495 |
rows_fetched_from_server_ps | 447 |
rows_buffered_from_client_ps | 447 |
rows_skipped_ps | 447 |
proto_binary_fetched_bit | 3253 |
proto_binary_fetched_bigint | 10629 |
proto_binary_fetched_json | 5419 |
proto_binary_fetched_blob | 2029 |
bytes_received_real_data_ps | 764412 |
