Run Time: 0.001142
Run Time: 0.000722
Run Time: 0.000291
Run Time: 0.002283
Run Time: 0.000497
Params: 0, ],, ],, XF\Pub\Controller\Forum, List, valid, , 1714829838,
Run Time: 0.000148
Run Time: 0.000677
Params: 1714828938
Run Time: 0.000390
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 175 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714828938)
Run Time: 0.000548
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 175 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712237838)
Run Time: 0.001606
Run Time: 0.001023
Run Time: 0.000856
Run Time: 0.000185
Run Time: 0.000252
Run Time: 0.001447
Run Time: 0.001937
bytes_received | 941792 |
bytes_received_change_user_packet | 714675 |
bytes_received_real_data_ps | 702668 |
