Run Time: 0.001179
Run Time: 0.000751
Run Time: 0.000320
Run Time: 0.003262
Run Time: 0.000605
:RO,
:RO, XF\Pub\Controller\Forum, List, valid, , 1714868858,
Run Time: 0.000137
Run Time: 0.000663
Params: 1714867958
Run Time: 0.000414
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 168 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714867958)
Run Time: 0.000544
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 168 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712276858)
Run Time: 0.001402
Run Time: 0.001419
Run Time: 0.000785
Run Time: 0.000236
Run Time: 0.000230
Run Time: 0.000257
Run Time: 0.000279
Run Time: 0.001420
Run Time: 0.000157
Run Time: 0.002060
