Run Time: 0.001571
Run Time: 0.000292
Run Time: 0.000475
Run Time: 0.000864
Run Time: 0.000375
Run Time: 0.003766
Run Time: 0.000727
Params: 0, wo , wo , XF\Pub\Controller\Forum, List, valid, , 1714860076,
Run Time: 0.000957
Params: 1714859176
Run Time: 0.000507
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 95 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714859176)
Run Time: 0.000661
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 95 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712268076)
Run Time: 0.002294
Run Time: 0.001357
Run Time: 0.001340
Run Time: 0.000297
Run Time: 0.000248
Run Time: 0.000351
Run Time: 0.000374
Run Time: 0.002410
Run Time: 0.000259
Run Time: 0.002249
