Run Time: 0.001269
Run Time: 0.000279
Run Time: 0.000806
Run Time: 0.000346
Run Time: 0.002747
Run Time: 0.000621
Params: 0, O<, O<, XF\Pub\Controller\Forum, List, valid, , 1714848763,
Run Time: 0.000142
Run Time: 0.000868
Params: 1714847863
Run Time: 0.000529
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 101 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714847863)
Run Time: 0.000782
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 101 | Using where |
Run Time: 0.000205
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712256763)
Run Time: 0.001481
Run Time: 0.001265
Run Time: 0.001163
Run Time: 0.000334
Run Time: 0.000272
Run Time: 0.001006
Run Time: 0.000285
Run Time: 0.000260
Run Time: 0.001519
Run Time: 0.002103
bytes_received | 942269 |
bytes_received_change_user_packet | 715152 |
proto_binary_fetched_bit | 2927 |
proto_binary_fetched_short | 2379 |
proto_binary_fetched_int24 | 912 |
proto_binary_fetched_bigint | 8349 |
proto_binary_fetched_float | 145 |
proto_binary_fetched_json | 4439 |
bytes_received_real_data_ps | 703085 |
