Run Time: 0.001133
Run Time: 0.000657
Run Time: 0.002501
Run Time: 0.000510
Params: 0, tn, tn, XF\Pub\Controller\Forum, List, valid, , 1714821590,
Run Time: 0.000151
Run Time: 0.000751
Params: 1714820690
Run Time: 0.000426
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 187 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714820690)
Run Time: 0.000650
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 187 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712229590)
Run Time: 0.001489
Run Time: 0.001267
Run Time: 0.000962
Run Time: 0.000239
Run Time: 0.000228
Run Time: 0.000308
Run Time: 0.000287
Run Time: 0.001677
Run Time: 0.002095
bytes_received | 942102 |
bytes_received_change_user_packet | 714985 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702946 |
