Run Time: 0.000908
Run Time: 0.000229
Run Time: 0.000657
Run Time: 0.000290
Run Time: 0.002549
Run Time: 0.000500
Params: 0, w}, w}, XF\Pub\Controller\Forum, List, valid, , 1715208934,
Run Time: 0.000137
Run Time: 0.000674
Params: 1715208034
Run Time: 0.000378
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 117 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715208034)
Run Time: 0.000525
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 117 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712616934)
Run Time: 0.001468
Run Time: 0.000999
Run Time: 0.000846
Run Time: 0.000152
Run Time: 0.001395
Run Time: 0.000151
Run Time: 0.001807
