Run Time: 0.001714
Run Time: 0.000263
Run Time: 0.000345
Run Time: 0.000795
Run Time: 0.000540
Run Time: 0.002784
Run Time: 0.000769
Params: 0, ޛ:, ޛ:, XF\Pub\Controller\Forum, List, valid, , 1714487724,
Run Time: 0.000322
Run Time: 0.000874
Params: 1714486824
Run Time: 0.000457
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 33 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714486824)
Run Time: 0.000888
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 33 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711895724)
Run Time: 0.001335
Run Time: 0.001195
Run Time: 0.001160
Run Time: 0.000250
Run Time: 0.000278
Run Time: 0.000291
Run Time: 0.000529
Run Time: 0.002218
Run Time: 0.000294
Run Time: 0.000292
Run Time: 0.002208
bytes_received | 941880 |
bytes_received_change_user_packet | 714763 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702736 |
