Run Time: 0.001136
Run Time: 0.000303
Run Time: 0.000257
Run Time: 0.000784
Run Time: 0.000348
Run Time: 0.003830
Run Time: 0.000654
;"W,
;"W, XF\Pub\Controller\Forum, List, valid, , 1714260538,
Run Time: 0.000811
Params: 1714259638
Run Time: 0.000431
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714259638)
Run Time: 0.000624
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 118 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711668538)
Run Time: 0.002035
Run Time: 0.001266
Run Time: 0.000983
Run Time: 0.000230
Run Time: 0.000208
Run Time: 0.000252
Run Time: 0.000482
Run Time: 0.002017
Run Time: 0.002445
bytes_received | 941547 |
bytes_received_change_user_packet | 714430 |
bytes_received_real_data_ps | 702413 |
