Run Time: 0.001161
Run Time: 0.000683
Run Time: 0.002312
Run Time: 0.000500
Params: 0, vxm, vxm, XF\Pub\Controller\Forum, List, valid, , 1714841618,
Run Time: 0.000143
Run Time: 0.000647
Params: 1714840718
Run Time: 0.000403
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 98 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714840718)
Run Time: 0.000533
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 98 | Using where |
Run Time: 0.000155
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712249618)
Run Time: 0.001239
Run Time: 0.000957
Run Time: 0.000873
Run Time: 0.000157
Run Time: 0.000265
Run Time: 0.001596
Run Time: 0.001961
bytes_received | 941981 |
bytes_received_change_user_packet | 714864 |
bytes_received_real_data_ps | 702829 |
