Run Time: 0.001238
Run Time: 0.000226
Run Time: 0.000238
Run Time: 0.001215
Run Time: 0.000462
Run Time: 0.002726
Run Time: 0.000576
Params: 0, wk`, wk`, XF\Pub\Controller\Forum, List, valid, , 1714734314,
Run Time: 0.000140
Run Time: 0.000753
Params: 1714733414
Run Time: 0.000374
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714733414)
Run Time: 0.000660
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712142314)
Run Time: 0.001226
Run Time: 0.001039
Run Time: 0.000854
Run Time: 0.000274
Run Time: 0.000146
Run Time: 0.000370
Run Time: 0.001365
Run Time: 0.002209
