Run Time: 0.001136
Run Time: 0.000223
Run Time: 0.000269
Run Time: 0.000706
Run Time: 0.000285
Run Time: 0.002579
Run Time: 0.000693
Params: 0, D, D, XF\Pub\Controller\Forum, List, valid, , 1714998834,
Run Time: 0.000657
Params: 1714997934
Run Time: 0.000607
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 158 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714997934)
Run Time: 0.000671
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 158 | Using where |
Run Time: 0.000240
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712406834)
Run Time: 0.001516
Run Time: 0.001185
Run Time: 0.001401
Run Time: 0.000243
Run Time: 0.000277
Run Time: 0.000225
Run Time: 0.000284
Run Time: 0.000476
Run Time: 0.001535
Run Time: 0.002481
bytes_received | 946880 |
bytes_received_change_user_packet | 719763 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707558 |
