Run Time: 0.001099
Run Time: 0.000698
Run Time: 0.000282
Run Time: 0.002598
Run Time: 0.000498
Params: 0, vc, vc, XF\Pub\Controller\Forum, List, valid, , 1715213754,
Run Time: 0.000135
Run Time: 0.000598
Params: 1715212854
Run Time: 0.000356
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 103 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715212854)
Run Time: 0.000483
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 103 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712621754)
Run Time: 0.001339
Run Time: 0.000978
Run Time: 0.000783
Run Time: 0.000149
Run Time: 0.000159
Run Time: 0.000261
Run Time: 0.001337
Run Time: 0.001853
