Run Time: 0.001564
Run Time: 0.000363
Run Time: 0.000367
Run Time: 0.001166
Run Time: 0.000429
Run Time: 0.003038
Run Time: 0.000736
Params: 0, 4", 4", XF\Pub\Controller\Forum, List, valid, , 1714536577,
Run Time: 0.000319
Run Time: 0.001132
Params: 1714535677
Run Time: 0.000436
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 22 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714535677)
Run Time: 0.000966
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 22 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711944577)
Run Time: 0.001927
Run Time: 0.001744
Run Time: 0.001269
Run Time: 0.000410
Run Time: 0.000317
Run Time: 0.000341
Run Time: 0.000338
Run Time: 0.000328
Run Time: 0.000565
Run Time: 0.002989
Run Time: 0.000266
Run Time: 0.000228
Run Time: 0.002688
bytes_received | 941807 |
bytes_received_change_user_packet | 714690 |
bytes_received_real_data_ps | 702683 |
