Run Time: 0.001114
Run Time: 0.000686
Run Time: 0.000278
Run Time: 0.002299
Run Time: 0.000508
:p,
:p, XF\Pub\Controller\Forum, List, valid, , 1714763121,
Run Time: 0.000137
Run Time: 0.000687
Params: 1714762221
Run Time: 0.000425
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 110 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714762221)
Run Time: 0.000576
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 110 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712171121)
Run Time: 0.001539
Run Time: 0.001039
Run Time: 0.000859
Run Time: 0.000155
Run Time: 0.000295
Run Time: 0.000310
Run Time: 0.001577
Run Time: 0.000152
Run Time: 0.002076
