Run Time: 0.001605
Run Time: 0.000256
Run Time: 0.000254
Run Time: 0.000786
Run Time: 0.000400
Run Time: 0.003033
Run Time: 0.000685
Params: 0, $, $, XF\Pub\Controller\Forum, List, valid, , 1715032295,
Run Time: 0.000815
Params: 1715031395
Run Time: 0.000547
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 144 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715031395)
Run Time: 0.000691
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 144 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712440295)
Run Time: 0.001553
Run Time: 0.001406
Run Time: 0.000964
Run Time: 0.000277
Run Time: 0.000256
Run Time: 0.000270
Run Time: 0.000303
Run Time: 0.000381
Run Time: 0.001584
Run Time: 0.000228
Run Time: 0.003268
