Run Time: 0.001085
Run Time: 0.000799
Run Time: 0.000317
Run Time: 0.002876
Run Time: 0.000530
Params: 0, D, D, XF\Pub\Controller\Forum, List, valid, , 1715204309,
Run Time: 0.000140
Run Time: 0.000630
Params: 1715203409
Run Time: 0.000919
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 133 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715203409)
Run Time: 0.000573
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 133 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712612309)
Run Time: 0.001344
Run Time: 0.000969
Run Time: 0.001027
Run Time: 0.000210
Run Time: 0.000287
Run Time: 0.001585
Run Time: 0.001917
