Run Time: 0.001435
Run Time: 0.000292
Run Time: 0.000305
Run Time: 0.000797
Run Time: 0.000466
Run Time: 0.002862
Run Time: 0.001128
Params: 0, 4T, 4T, XF\Pub\Controller\Forum, List, valid, , 1714812654,
Run Time: 0.000950
Params: 1714811754
Run Time: 0.000595
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 96 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714811754)
Run Time: 0.000725
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 96 | Using where |
Run Time: 0.000239
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712220654)
Run Time: 0.001415
Run Time: 0.001586
Run Time: 0.001439
Run Time: 0.000401
Run Time: 0.000277
Run Time: 0.000367
Run Time: 0.000449
Run Time: 0.001805
Run Time: 0.000282
Run Time: 0.002501
bytes_received | 942120 |
bytes_received_change_user_packet | 715003 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702964 |
