Run Time: 0.001234
Run Time: 0.000764
Run Time: 0.000285
Run Time: 0.002420
Run Time: 0.000593
Params: 0, t
q, t
q, XF\Pub\Controller\Forum, List, valid, , 1714286145,
Run Time: 0.000139
Run Time: 0.000621
Params: 1714285245
Run Time: 0.000368
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 113 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714285245)
Run Time: 0.000514
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 113 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711694145)
Run Time: 0.001335
Run Time: 0.001003
Run Time: 0.000864
Run Time: 0.000244
Run Time: 0.001173
Run Time: 0.000159
Run Time: 0.001894
bytes_received | 941547 |
bytes_received_change_user_packet | 714430 |
bytes_received_real_data_ps | 702413 |
