Run Time: 0.001439
Run Time: 0.000352
Run Time: 0.000783
Run Time: 0.000316
Run Time: 0.002407
Run Time: 0.000556
Params: 0, ِ , ِ , XF\Pub\Controller\Forum, List, valid, , 1715030638,
Run Time: 0.000142
Run Time: 0.000729
Params: 1715029738
Run Time: 0.000472
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 188 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715029738)
Run Time: 0.000629
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 188 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712438638)
Run Time: 0.001420
Run Time: 0.001056
Run Time: 0.001025
Run Time: 0.000243
Run Time: 0.000244
Run Time: 0.000316
Run Time: 0.000449
Run Time: 0.001743
Run Time: 0.002135
